'85 TPI system onto '91 TBI engine issues
Old Jan 24, 2002 | 05:28 PM
2thpick's Avatar
Ok, if I take an '85 TPI system and try to put it on a 91 TBI 305, what problems will I hit?
*Center intake bolts. I know about this one.
*What about the distributor? Does the '85 distributor have to go with the '85 computer, or will the '91 TBI distributor work with it?
*I know the '85 computer sucks, but this engine is stock and I'm not into prom burning.
*What about fuel lines? I will have the donor car so how hard will it be to use the '85 fuel lines?
*The fuel pumps need to be swapped too right?
*Oh another thing, the '91 is a 5 speed and the '85 is an automatic, so will the computer throw a tissy, or will it just not care? What about a VSS signal on the '85 system?
Old Jan 25, 2002 | 04:28 PM
2thpick's Avatar
ttt
Old Jan 25, 2002 | 05:04 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
VSS is a seperate box on the 85. On the 91 TPI ECMs, it is built in.
I am not too sure about the 91 TBI ECM, it could be built in as well. If you have to, take the box from the 85 and use it in your 91. It's a small yellow box with 2 Edge connectors on it, one 2 pin and one 4 pin.
Splice the wires from the VSS sender on the tranny to the VSS Buffer box. Speedo should work fine after that.
Not sure about the other questions though.
Old Jan 28, 2002 | 08:02 AM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
Basically, the entire fuel and computer system will have to be taken from the donor car. Fuel lines, fuel pump, distributor, and computer and wiring are all different. If you can find it, you will be much better off with an 86' or later computer setup, but if you can't get it, the 85' will do. Also, if you want to keep the 5-speed, you will a flywheel off an 85' or earlier car that had a one peice rear main seal like your 85' motor. The electronics will work fine without the auto being there. Good luck.
Old Jan 28, 2002 | 11:34 PM
2thpick's Avatar
I'm going to be keeping the '91 motor, I'm just swapping the tpi system. The motor in my car is a brand new GM motor. I might put the '85 motor in my s10.
Old Jan 29, 2002 | 11:55 AM
Car: '89 GTA
Engine: ZZ6TPI
That's right, you did say you were just swapping the TPI system and not the entire engine. Then you don't have to wory about the flywheel.
MustangBeater20
Oct 29, 2022 09:20 PM
midge54
Dec 27, 2019 04:14 PM
Jae992
Aug 27, 2015 09:07 AM
beachrodder
Aug 25, 2015 08:05 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
