So my question is, with an SLP cold air intake do you have to use a K&N air filter (or any other oiled filter)? I ask because I have read the oil will eventually cause issues with the MAF. I have a 1987 GTA with the box air damn and MAF connected. If I were to use a non oiled air filter with the SLP set up would that negate the cold air element?
TTOP350
close
- Join DateOct 2001
- LocationIl
- iTrader Positive Feedback100
- iTrader Feedback Score(9)
- Car1989-92 FORMULA350 305 92 Hawkclone
- Engine4++,350 & 305 CIs
- Transmission700R4 4800 vig 18th700R4 t56 ZF6 T5
- Axle/Gears3.70 9"ford alum chunk,dana44,9bolt
- Liked:1,148 Times in 749 Posts
It uses the factory size round filter in the SLP box. No it doesn't have to be oiled.
I've never had an issue with a K&N oiled filter with the hot wire MAF sensor.
Reddragon88gta
close
- Join DateApr 2017
- LocationNorthern NY
- iTrader Feedback Score(1)
- Car1988 Trans Am GTA and 1979 Trans Am
- Engine5.7 L98
- Transmission700R4
- Axle/GearsBorg Warner 9 bolt 3.27
- Liked:445 Times in 342 Posts
I also have never had a problem with my K&N filter/SLP cold air box causing a problem with the MAF.
Mine used the factory K&N filter, same as the stock replacement K&N filter.
Thank you guys for all the responses! Maybe I read miss information or maybe they were more “concerns” of causing issues and not actual real life evidence. Either way thanks guys! I really like the look of the SLP CAI over the air box I have in my 87, any performance gains will just be a bonus lol
Quote:
Oil contamination on a modern electronic MAF sensor is a real concern. The MAF sensors on our cars are an older hot wire design that has a burn off function that heats and burns contaminants from the wire, so in effect is self cleaning.Originally Posted by Gunmetal87
Thank you guys for all the responses! Maybe I read miss information or maybe they were more “concerns” of causing issues and not actual real life evidence. Either way thanks guys! I really like the look of the SLP CAI over the air box I have in my 87, any performance gains will just be a bonus lol Quote:
Originally Posted by TransamGTA350
Oil contamination on a modern electronic MAF sensor is a real concern. The MAF sensors on our cars are an older hot wire design that has a burn off function that heats and burns contaminants from the wire, so in effect is self cleaning. great info that I didn’t know thank you!
I've never had an issue with mine either. The filter should come pre-oiled, which means it will have been oiled correctly and won't cause any issues. When such issues occur, it's after people have cleaned them and re-oiled them. They'll over-oil the filter, which can then take days to drain, so if it's reinstalled too soon, that excess oil is going to spray through the MAF.
