Small Misfire at Idle
Old Sep 28, 2025 | 01:34 PM
FrankDAGorilla's Avatar
Hello,
I have an 87 5.7, appears to be all stock. 38K miles. Small puff of smoke when starting up, cranks good, runs/ drive good. Appears that I am getting a small misfire at idle. I have replaced the fuel filter, fuel pressure key on engine off is 42 PSI. Running is 35 PSI. Have done a complete tune up, new ignition module, new O2 Sensor, showing no codes. What would y'all suggest as why I am getting this small Misfire and Puff of White Smoke at start up.
Old Sep 28, 2025 | 06:38 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: Small Misfire at Idle
Blue smoke is much more common. Valve seals tend to leak. White smoke is usually coolant. Few options. You could have a leaky injector, head gasket (not exactly my expected problem) or even an intake leak. Pressure test the coolant and see if you have a drop, see if you can find the leak. Those would be my initial suspects.
Old Sep 28, 2025 | 11:05 PM
Airwolfe's Avatar
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
Might also be a problem with the 9th Cold Start Injector system.
Old Oct 1, 2025 | 10:56 AM
wolf_walker's Avatar
Car: 86 Corvette z51 4+3
My 86 has had a small random idle misfire since I've had it, after replacing literally anything anyone could name and it having good compression and mpg/power, no smoke, etc etc I've decided it's
just who it is as a person. Could be a valve not sealing well but the idle vacuum is rock steady, I've drowned the intake in flammable brake cleaner and found no vacuum leaks, if it's a worn
cam it'll tell me eventually I figure but it's quiet right now, meh.
Runs great otherwise, I've given up on it for now.
Freejack
Dec 3, 2020 02:44 PM
305RSlc
Nov 8, 2004 01:35 PM
FbodTrek
Nov 8, 2004 09:31 AM
OUTATIME GTA
May 19, 2003 06:58 AM
