TPI remote Adjustable regulator
Old Jan 19, 2026 | 04:44 PM
rednblackrs's Avatar
Car: 01 mustang GT
Engine: 4.6
Transmission: tr3650
Axle/Gears: 3.73 Posi
I have just wrapped up my remote fuel pressure regulator install. My install is in a square body truck, but it would look even cleaner in a 3rdgen. Easy access to adjust it and visible fuel pressure gauge. And it cleans up the engine bay nicely. I will eventually move the feed line to the back of the engine.
Old Jan 19, 2026 | 04:46 PM
Car: 01 mustang GT
Engine: 4.6
Re: TPI remote Adjustable regulator
Adjustable regulator temporarily mounted here until I get the AC up and going.
Old Jan 23, 2026 | 09:33 PM
TallTim's Avatar
Car: 1989 Formula T-Top
Engine: 350 TPI, twin turbo
I can appreciate what a PIA it is to adjust the FP in the stock location, does your setup require you to adjust it more than once to get it dialed in? I added a 90* fitting and the gauge right at the schrader valve and that was it for me.
Old Feb 8, 2026 | 11:46 PM
Car: 01 mustang GT
Engine: 4.6
I have not had to adjust it more than once. I already had an adjustable on it in the original spot and a gauge that connected to that port on the rail. But I didnt like how the piping ran through all of the pulley setup. Also the Truck fuel feed is on the passenger side frame rail so this made that connection a little easier. Eventually I plan on moving the regulator to the fender or maybe somewhere on the firewall.
89305formula
Apr 6, 2022 09:57 PM
mynameisfrank89
Jul 24, 2020 10:29 PM
trytofly
Aug 6, 2019 09:22 PM
oscarfromla
May 22, 2016 09:08 AM
serpentineocean
Convertibles
45
Oct 17, 2006 05:59 PM
