MAF sensor loose, bad or does it matter?
Old Jan 26, 2002 | 01:14 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
My dad showed a buddy of his my car today, and he saw that the MAF sensor was loose and said it shouldn't be that way and will effect gas mileage. Does it matter? If so, where do they sell the ring that holds it on, but with a screw on the top to tighten it? Any help is appreciated. Thanks in advance.
Old Jan 26, 2002 | 02:03 PM
Guest
Guest
Posts: n/a
Depends on what side its loose as to if it matters or not. The side towards the engine has to be secure and leak free.
I'd secure it just for peace of mind. Vibration and electronics dont always get along so well, no point in adding more.
Old Jan 26, 2002 | 04:16 PM
lancer5067's Avatar
vibration is such a concern with MAF's that GM actually put bushings on the securing fasteners to prevent it. Also on my aftermarket Wells MAF it isn't even bolted down so it won't shake and rattle, because it will give erratic readings. Fix it before the element takes a poop!
89GTAOz
May 16, 2020 09:31 AM
chazman
Aug 28, 2018 03:25 PM
Logan Bryant
Aug 27, 2015 11:52 AM
Bert87
Aug 23, 2015 03:50 PM
