EGR questions - - - - ->
Old Jan 27, 2002 | 11:08 AM
Poppa Chubby's Avatar
Car: Vert IROC Camaro
Engine: 355ci
Axle/Gears: 9-bolt w/3.45s
Is there a way to eliminate the EGR system and charcoal canister from a MAF TPI?
My AIR pump is already gone and I have no emissions testing here.
Anyone know?
Thanks.
Old Jan 27, 2002 | 11:49 AM
360Iroc's Avatar
just get rid of the canister and take off the egr valve and cap it off with a gasket and block off plate, i made my plate out of scrape body metal from my body shop, it was an easy process
Old Jan 27, 2002 | 09:38 PM
Engine: 355ci
Would doing that adversely affect my TPI? Would it start popping error codes on me?
Old Jan 27, 2002 | 09:42 PM
RedFirebird's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L TPI (L98)
Transmission: 700RJunk
Yes it will throw codes unless you burn a new PROM.
Old Jan 29, 2002 | 05:36 PM
360Iroc's Avatar
no you wont get any codes, if you a take the belt off your smog pump does it set a code. mine didnt and doing this didnt either
Old Jan 29, 2002 | 06:57 PM
Kenwood's Avatar
Car: 1987 GTA
Engine: PT88 Turbo DART 406
Transmission: th400
Axle/Gears: 9" ford
Removing this stuff will not throw codes...BUT One facet of it will if I remember correctly...The EGR solenoid....You can remove the EGR valve But you need to plug the valve vacuum line at the solenoid and keep the solenoid on the car and plugged in...Actually the easiest way to do it is to Pull the tube out of the rubber elbow at the solenoid and just break off a golf tee in there or push a cap headed screw in there....As long as the solenoid stays plugged in and the line is blocked that fools the computer into thinking the valve is there and keeps it from causing a vacuum leak....Thus NO CODES...All of my emmisions stuff has been gone for 4 years now and no codes...My solenoid is still there with a cap screw plugged into it ...No one would ever notice the screw is out of place unless I pointed it out.. ;-)
Kenwood
1987 vortech supercharged 355 GTA
1985 Corvette
2001 TRD Celica GTSM6
Bubbajones_ya
Aug 28, 2015 02:17 AM
mdtoren
Aug 23, 2015 12:52 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
camaroken83
Aug 10, 2015 11:35 AM
