L98 Heads - cc volume
Old Jan 28, 2002 | 02:00 PM
89Iroc-ZL98's Avatar
Car: 1989 Chevrolet Camaro IROC-Z
Engine: 5.7L TPI
Transmission: WC T-5
What is the combustion chamber volume of the L98 Iron heads? I cannot remember (getting old) and can only find numbers for the aluminum (58cc).
Thanks for the help.
Also, anyone know the flow numbers on the irons, intake and exhaust (stock form), for comparison.
Old Jan 28, 2002 | 03:20 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
No clue on the flow numbers, but the chambers are supposed to be 64cc's.
Old Jan 28, 2002 | 09:24 PM
Black 91 Z28's Avatar
Car: 1991 Camaro Z28
I seached on the board and found these numbers
350 Cast Iron # 083
Lift/Intake/Exhaust
.100 44 41
.200 101 82
.300 155 125
.400 182 137
.500 196 140
They came from https://www.thirdgen.org/techbb2/sho...?threadid=43197
In case ya wanna see what else was written.
Hope it helps.
David
Old Feb 1, 2002 | 09:01 PM
Engine: 5.7L TPI
Thanks for the info 8Mike9.
Black 91 Z28, thanks for digging up these numbers. I really wanted to have something to compare with. This really helps.
Old Feb 2, 2002 | 08:25 AM
CORKVETTE1's Avatar
the cast steel heads are 76 cc the same plain jane heads they put on everything else
Old Feb 2, 2002 | 09:13 AM
Guest
Guest
Posts: n/a
Same as other post, all the L98's I've had apart have 64cc heads. Measured them myself.
Old Feb 2, 2002 | 11:15 AM
CORKVETTE1's Avatar
like i said the vette steels i measured were 76cc dont know i never cc a camaro head but i thought they should be the same dont know
Old Feb 2, 2002 | 03:29 PM
Guest
Guest
Posts: n/a
Apparently not.
Very strange.
Old Feb 2, 2002 | 05:06 PM
CORKVETTE1's Avatar
what do the stock pistons look like in the 350 camaro engine the vettes are forged flat tops with 2 valve reliefs
Old Feb 2, 2002 | 07:10 PM
Guest
Guest
Posts: n/a
I'd have to look to see if they have a slight dish or not (I think they do) but there are 4 valve reliefs and they are not forged.
Old Feb 2, 2002 | 09:24 PM
CORKVETTE1's Avatar
that is probally the difference they put smaller chambers on the heads and put a dished 4 valve relief piston in there to keep the comp the same
Old Feb 7, 2002 | 08:02 PM
Engine: 5.7L TPI
OK, what about the Corvette L98 aluminum heads? Are they 58, 64, or the 76 cc that seems to be out there?
If they are 58, what would the compression ratio be on a Camaro L98 with stock pistons?
Old Feb 8, 2002 | 01:25 AM
CORKVETTE1's Avatar
YES THEY ARE 58 CC THE COMP WOULD JUMP APPROX .8 OF A POINT ON A 350 ENGINE
Old Feb 8, 2002 | 05:06 PM
u r sofa king we tah did's Avatar
85 was the only year forged pistons were used in vettes, but yeah iron vette heads had 76cc's and f-bodies had 64cc's
Old Feb 8, 2002 | 05:31 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Originally posted by madmax
Apparently not.
Very strange.
ROFL!!!! :lala:
lt500r55
Sep 1, 2021 01:30 PM
CRFred
Feb 7, 2016 11:39 PM
gixxer92
Sep 1, 2015 04:32 PM
italiano67
Aug 31, 2015 06:04 PM
