LT1 24 lbs.??
Old Jan 28, 2002 | 11:21 PM
JuGrNuT350's Avatar
LT1 24 lbs.??
Will 24 lb. injectors work out alright w/ a lightly modded TPI w/ just heads, cam & some mild porting?? Will it be 2 rich at idle??
Thanks,
-Timbo-
Old Jan 28, 2002 | 11:50 PM
ScreaminDeamin85Z's Avatar
they will work just like any other injector but your car wont run at its "potential" without a PROM calibrated for these injectors. I just pulled out my 24# SVO injectors today because it was running too rich.
Old Jan 29, 2002 | 01:51 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
It depends on what you mean by lightly modded engine with heads and cam. Mine was on the edge with 22lbs. I added some 24lbs and retuned the chip, and I'm good to go. When changing injector size, you almost always have to have a custom chip for them. Thats the only problem.
Old Jan 29, 2002 | 07:41 PM
JuGrNuT350's Avatar
I am planning on a custom chip too.... I really wanna learn how to burn my own chips.... It sounds like you can get good enough to do a better job yourself that telling someplace to burn one for you... O yea the heads I'm talking about are TF Twisted Wedge G2s, crane 104224 cam (.452/.465 214/220)
Thanks again,
-Timbo-
Old Jan 30, 2002 | 02:08 AM
Kevin91Z's Avatar
Be careful with those twisted wedge heads, you might need the special pistons to go with them.
Old Jan 30, 2002 | 11:41 AM
JuGrNuT350's Avatar
I know I need special lenght pushrods but you're the first to mention the pistons.... I was also thinking about this would ported Cast Iron Vortecs perform the same as the Trick Flows?? I know heat dissipation & weight would win out w/ alu. heads but what about flow?
-Timbo-
Old Feb 6, 2002 | 01:34 AM
Kevin91Z's Avatar
Since the valves are twisted in the combustion chamber (hence the name) they wont line up with the valve reliefs in normal pistons. A friend got some and the valves hit the pistons. He sent the heads back and got the regular 23º heads, after he found out the pistons cost $500 from Jegs/Summit.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
L0tuS
Sep 4, 2015 11:16 PM
