what kinda heads??
Old Jan 29, 2002 | 09:15 PM
Nasty_Bird_'90's Avatar
what kinda heads??
hey guys. i'm building a 350 for my firebird and am trying to figure out what kind of heads to put on. i'm looking for low to mid 13's. can i get that out of stock heads, or should i go with vortecs or something along those lines. from what i understand, the vortecs also require an aftermrket intake manifold. any info would be appreciated. thanx
Old Jan 29, 2002 | 09:28 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
I think most people will recomend the AFR heads but, I wan't to give the twisted wedge G2 heads a shot this spring. along with some slp runners, ported base. I think this should give more than sufficiant breathing. for most other upgrades.
I am getting pretty close to low 13's with what I have(13.7 best) I should brake 13's with the spring upgrads..there are people hear doing it with stock heads though.
Old Jan 30, 2002 | 09:19 PM
how are the AFR compared to some vortecs in terms of price, performance, etc..? i'd like to throw some vortecs on but i don't want to get into changing out the intake manifold. gets to be too much $$$. also, where's a good place to get them? thanx
Old Jan 30, 2002 | 09:28 PM
rockind78's Avatar
Well think of it this way: If 13 are all you will EVER be after, then yes, I would recommend the Vortecs. If you you think you might want more later, than I would go with the AFR's. Also, as far as cost goes, last time I checked, the prices for these items were as follows:
Vortec heads-- $450--->Jegs
Vortec Intake--$400---->SDPC
AFR Heads----$1200----->AFR
Upgraded springs & Machine Work---?????
Going by these prices, I would recommend the Vortecs, because as it stands, there is a $350 difference in price between Vortec equipment and the AFR heads. Now I don't know what better springs and a little machine work for a higher lift cam would cost, but my guess would be less than $350. Hope this helps.
Old Jan 31, 2002 | 09:19 PM
all that sounds good, but will the vortecs bolt right up to the L98 block? i was told i needed a new intake manifold as wel. true? also, the $450 is assembled right? thanx
Old Jan 31, 2002 | 09:31 PM
87transam5.7tpi's Avatar
yup thats true, snoggin-dickey make one for $400 bucks. something to think about. taht is for TPI though, if your goig carbed the intakes are like $30 more.
z28addict8490
Sep 5, 2015 03:56 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
FreeSpirit
Aug 29, 2015 05:47 PM
Thaney9
Aug 29, 2015 03:16 PM
