Bad hesitation
Old Jan 30, 2002 | 01:18 PM
Drekken's Avatar
Bad hesitation
Oiy! Okay so, a couple weeks ago I was driving on the higway, and crusing about 80 mph and the SES came on after about 30 min, stayed on till i got home and had the car off, when i started it up again the SES was gone and didnt come back it seemed until I had been travelling at about 80+ for a while.
So then today I was parked idling talkin on the phone when the car shut off, it had been runnig and driving for about 20 min in the city. I started it back up and the SES light was on and the car was hesitating awfully.
I got back home turned it off and after about 10 min of runnin and errand came out started it back up to move it to a different spot and it was running fine.
So.. what broke?
Is it the EGR? If so what part of the EGR? What should I replace?
Thanks in advance
- Tom
Old Jan 30, 2002 | 02:11 PM
tpi_roc's Avatar
You got an S.E.S light, tell us what code its throwing
Old Jan 30, 2002 | 03:45 PM
Drekken's Avatar
oops, forgot to tell you. I'll hafta pull the codes again, but when I pulled them after it first started i was getting a 32. which is the EGR isnt?
THanks
-Tom
Old Jan 30, 2002 | 03:47 PM
tpi_roc's Avatar
Gotcha
Maybe the EGR is getting stuck.. That would explain your rough idle and hard starting. IF you're breathing exhaust gases at idle your engine will run like crap, it isn't supposed to recycle untill you're at cruising speeds.
So sounds to me like its stuck or getting fruity
Old Jan 30, 2002 | 04:03 PM
DrekkenX's Avatar
So do I just rip the thing out or something? :O
Tom
Old Jan 30, 2002 | 04:06 PM
tpi_roc's Avatar
Thats what I did
Dont even rip it out, first unplug the solinoid and see if your problem stops, if not pull the actual EGR and block it off, you'll still have the SES light, but it'll run like a champ
Old Jan 30, 2002 | 04:14 PM
Steve91Z28 L98's Avatar
Car: 1991 Camaro Z28
Hmmm. I wonder why I havn't been getting a code 32 with my motor. I don't have any kind of egr hooked up to my LT4 intake so I would think it would throw the code immediately. The electrical connection for the egr solenoid is just sitting there unplugged.
Old Jan 30, 2002 | 04:16 PM
DrekkenX's Avatar
I pulled the codes again and got 12,32, and i think 42. 12 is just the ignition right? Whats 42? :O Thanks
- Tom
tpi_roc's Avatar
Interesting
guess what....
If you burn your own prom you can turn off the EGR diagnostics that throws the code
Old Jan 30, 2002 | 04:18 PM
tpi_roc's Avatar
12 = very bad....
Go make sure that your ECM is plugged in very snug, and that your mem cal is seated correctly
Old Jan 30, 2002 | 04:21 PM
DrekkenX's Avatar
I'm lookin at this page and it said that this about 12 This code will flash whenever the diagnostic terminal is grounded with the ignition turned On and the engine not running. If additional trouble codes are stored in the ECM they will appear after this code has flashed three times. If this code appears while the engine is running, no reference pulses from the distributor are reaching the ECM.
It said 42 was:
Electronic Spark Timing bypass circuit or EST circuit is grounded or open. A malfunctioning HEI module can cause this code.
So maybe my distributor and EGR have died?
Old Jan 30, 2002 | 04:25 PM
tpi_roc's Avatar
Maybe a short?
Old Jan 30, 2002 | 04:37 PM
DrekkenX's Avatar
What do you think may have shorted? Is the HEI Module the distributor? How does that short? Is the EGR and EGR Valve two different components? I've never had to replace one, how does it short? Thanks !
Old Jan 30, 2002 | 04:44 PM
tpi_roc's Avatar
The module is inside the distributor at the base.
There's an EGR "valve" and an EGR "Solinoid" that controlls the valve
The EGR valve is under the plenum (on tpi) its kinda bronze looking. Follow the vacuum lines coming off of that and you'll find the solinoid.
Old Jan 30, 2002 | 07:06 PM
DrekkenX's Avatar
Roger Thanks!
junior419
Apr 7, 2025 11:35 AM
69GTOby
Apr 18, 2016 02:34 PM
85 Jimmy
Sep 30, 2015 07:56 AM
webeeZ28
Sep 14, 2015 12:00 PM
Ranbo108
Sep 9, 2015 12:20 PM
