Unknown relays
Old Jan 31, 2002 | 10:48 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
Unknown relays
i'm almost done with my 305TBI to 350TPI swap.i have two unkown relays plugs that should sit some where around the stock air box.
can you tell me what these relays are for?:rockon:
Old Jan 31, 2002 | 10:55 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
They are for the cooling fan relays. One sits right next to the radiator, the other sits over on the fenderwell by the coolant recovery tank.
Old Jan 31, 2002 | 10:59 AM
91banditt2's Avatar
Engine: 5.7 HSR
Damn dude!!
damn that was a fast repsonce!
well since i'm wiring my fan to a switch i'm not going to need those relays.....right?
Old Jan 31, 2002 | 11:24 AM
ploegi's Avatar
Engine: 5.7 TPI
Depends on how you wire it. You may want to put the relays in there, and just switch them. The relays are pretty cheap, (bout nine bucks at autozone) and wiring the relays will be easier than trying to run a fat enough wire to handle the current draw of the fans.....
Have fun now.
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
lanceflame44
Sep 25, 2015 12:28 PM
gta892000
Sep 16, 2015 12:37 AM
