aluminum heads inside (and injector gurus)
I've been lurking forever, this is my first post I believe.
Do auminum heads (corvette or aftermarket) LOOK any different then stock when they're in? Can you just look at any exposed part of the heads and say "Hey, nice aluminum heads!" or do they look the same as the iron?
Also, what size injectors (and a brnad anyone recomends?) would I need to feed a nitroused 383 TPI? The old ones seem to be wearing thin...
b e y o n d
b e y o n d
Car: 87 IROC (low 12's)
Engine: 400 sbc .040 over
Transmission: 700r mod
unless you have seen a lot of heads
you might can
see a slight difference in port size,port shape,and differences in combustion chamber
you might cansee a slight difference in port size,port shape,and differences in combustion chamber
Re: aluminum heads inside (and injector gurus)
b e y o n d
b e y o n d
They say 24 lb injectors are good for up to 450 HP. I have 24's in my 406 (no nitrous) and they are plenty big for 'me'.
ambainb
Apr 25, 2016 09:21 PM
