check the specs on this motor!!!! what kinda power??
i was wondering what horse power i would get out of the engine im building , i have a 1972 camaro z 28 350, im havinging it boared .60 over domed pistons with 194 heads to make it around 10-1 compression. the heads are ported and polished
and i am using a mild cam because im useing a tpi system with 89 vette injectiors , i have a turbo 400 trans and 342 posi in my 85 trans am i am wonding the hp and quarter mile time
Car: Damn
Engine: This
Transmission: New Stuff
Theres not alot of info to work with here, but a 10:1 350 with ported stock heads, mild cam, stock tpi, manifolds?
I'd guess 260-280 hp at the flywheel.
I'm not even going to try to guess what she'll run, wouldn't help you any, and wouldn't be close.
If you have some more detailed info on the cam, heads, and basically everything else, you'd probobly get a much better guess.
BlackphantomZ28
Aug 31, 2015 10:29 AM
