Swirl Port Heads?
Old Feb 5, 2002 | 02:07 AM
JR4444's Avatar
Swirl Port Heads?
What exactly are Swirl port heads? I think they are heads the have a "slide" behind the intake valve, but I'm not sure. Do our cars have these type of heads? Are they good or bad? Any info you have on them would be appreciated. Thanks
Old Feb 5, 2002 | 10:02 AM
88gta305's Avatar
Car: 77 Corvette
Engine: ZZ3/nitrous
Transmission: THM 400
Generally speaking, they are not a performance head. They can be used to build a torque monster, thats about all. There is a spiral ramp around the intake valve stem which is used to intruduce a large swirl of the fuel / air mix in to the combustion chamber. This works really well and is very efficient. Unfortunately, this very same ramp, hinders the flow required once the rpms build, thus limiting the effective power band of the cylinder heads.
I have them in my GTA, (temporarily)m, and it pulls extremely hard from idle to 4500 rpm, but the engine is dead from then on up.
They are really designed for truck use, i.e. torque, pulling power.
Hope this is of some help.
Cheers
Richard
MoJoe
Sep 24, 2015 09:12 PM
italiano67
Aug 31, 2015 06:04 PM
Brendankup
Aug 30, 2015 01:46 PM
355tpipickup
Alternative Port EFI Intakes
Aug 29, 2015 10:47 PM
86White_T/A305
Aug 17, 2015 12:16 AM
