will i hit low 13's
Old Feb 5, 2002 | 06:42 PM
redtail2426's Avatar
will i hit low 13's
LT1 with ram air,mass air sensor, 58mm throtle body, borla cat back, cold air induction, chip,
Old Feb 5, 2002 | 08:15 PM
Greg90iroc's Avatar
no
Old Feb 6, 2002 | 08:18 AM
TheWraith's Avatar
Car: 1987 Camaro IROC Z28
Engine: 355
Transmission: 1994 T56
Axle/Gears: BW 3.27 (stock)
Re: will i hit low 13's
none of that stuff is gonna make any significant difference over stock...and a stock LT1 is a low 14 second car, maybe high 13's with a 6 speed, a few mods and a good driver.
anyway, if you do all that except the 58mm TB, you might see 2 or 3 tenths compared to stock. The 58mm tb will do nothing, and might even cause you to run slower on a stock motor. You just don't need a tb that big. It's like running tunnel ram with two holley 600 double pumpers on a stock smogger 350. doesn't make any sense.
and why are you asking about an LT1 on a thirdgen board anyway?
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
db057
Apr 28, 2019 07:45 AM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
87camaro87
Sep 9, 2015 10:29 PM
adelane
Sep 9, 2015 08:51 PM
