Help! My car died this morning
Old Feb 6, 2002 | 11:30 AM
genyuschrist's Avatar
For the last month or so my car has been running kinda bad, it hesitates and chokes when i accelerate and also idles very rough.
Well i havent been able to figure out what is wrong. THis morning on the way to work i stopped at a stop sign and it started sputtering and dropped down to 300rpm and when i stopmed on the gas pedal nothing happened and it finally just cut off and would not start again for about 20 minutes. After i got it started i made it to work about 1/2 a mile away and it did the same thing. It will run for a minute , sputter for a few seconds then cut off. Can somebody maybe give me some suggestions on whats wrong Thanks!
Old Feb 6, 2002 | 12:02 PM
Ant87IROC's Avatar
Car: 87 IROC Z28
Transmission: TH700R4
When was the last time you had a tune-up? Sounds like that may be your probelm, also do you have an external coil? You might want to check that ignition module under the cap... it may be going bad. I had something similar to that, my car died, but it woudln't start after it died and i pulled the cap and changed ignition module and its been runnin smooth ever since!
Old Feb 6, 2002 | 04:20 PM
It has new plugs and wires.... It started running bad after i put my transmission back in. Would that throttle position cable have any thing to do with it running bad. I started it again this afternoon and drove it about 5 miles and it never cut off, so i dunno... Ill check that ignition module. Does anyone think it could be a sensor of some kind?, i dont really know jack about fuel injection systems and all this computer business.
Old Feb 6, 2002 | 04:45 PM
JR4444's Avatar
IAC (Idle Air Control Sensor) It's a sensor on the Throttle Body that controles the idle. Should be really easy to fix when you buy the sensor and find where it goes.
Old Feb 6, 2002 | 07:11 PM
Thanks guys, ill try both things ive been suggested, and ill post again if this works or doesnt work.
Old Feb 7, 2002 | 09:17 PM
u r sofa king we tah did's Avatar
you might want to check to see if you are getting good fuel pressure WHILE the problem is occuring. carry a fuel pressure gauge with you to see if your pressure is dropping during the problem. if so your pump could be on its way out. i dont see it being the fuel filter, but stranger things have happened, plus it is cheap so you might want to change that anyways.
Wade787b
Sep 29, 2015 01:15 PM
apie2546
Aug 10, 2015 05:43 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
