What year heated O2 sensor are you guys running?
Old Feb 7, 2002 | 10:30 AM
BlazinOR's Avatar
Since I got the new injectors in and the BLM's are where they need to be, the motor takes a good bit longer to get into closed loop (not running lean anymore, hence cooler exhaust) - I have hedman headers and the O2 sensor is in the collector, so I know that is a factor. Want to go with a heated O2 sensor.
And correct me if I am wrong please, but the other two wires for the O2 sensor are the power (hooked up to a 'key on' source), and a basic ground.
Anyone have the GM part number or an aftermarket part/mfg that you recommend?
TIA
Old Feb 7, 2002 | 11:28 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I told the dealer I wanted an oxygen sensor for a ZR1 corvette. Since they had it in stock, I'm guessing it's an extremely common part. My dealer hasn't even ever seen a ZR1, nevermind sold or serviced one. :sillylol:
And yeah, the 2 white wires are power and ground, and are interchangable. There's a thread going on about how to wire it in, so I'd do a search. I'm sure it'll be helpful when it comes time to install it.
Old Feb 7, 2002 | 12:44 PM
BlazinOR's Avatar
Thanks very much.
I will search for that thread, seem to remember it..............something about wiring it into the fuel pump circuit.
Old Feb 7, 2002 | 03:38 PM
Jim85IROC's Avatar
Yup, that's it. The fuel pump is how I wired it, but others have done it differently. Since the stock wire runs right into the harness at the brake booster, the fuel pump relay made a lot more sense to me than to try and chase wires all over the engine bay or into the interior.
Old Feb 7, 2002 | 05:25 PM
BlazinOR's Avatar
And with it 'sharing' the fuel pump circuit, no problems with low fuel pump voltage?
Thanks!
Old Feb 8, 2002 | 07:37 AM
Jim85IROC's Avatar
Thanks!
I've had no problems. The oxygen sensor draws very little current, so it's well within the capabilities of the relay to supply both circuits.
Old Feb 8, 2002 | 10:53 PM
Mark_ZZ3's Avatar
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
The cheapest one I found was from a 1991 S10. It is an Ac delco part number, AFS-74, GM # 25312179. There is a few of them around the AFS-74, like AFS-73, 72, 75, etc. The only difference is the plug on the end.
As for power, run a seperate ign fuzed wire. No sense introducing a problem with your fuel pump. Granted it would be rare, but why take the chance of causing a problem with your fuel pump.
CAr operates without an O2. Not without a fuel pump.
Mark.
gta892000
Aug 11, 2019 11:16 AM
86IROC112
Nov 27, 2015 09:54 AM
85 Jimmy
Sep 30, 2015 07:56 AM
BLK87Z
Sep 18, 2015 11:29 PM
