Why did 90-92 plenums "3rd" air passageget 86'ed?
Old Feb 7, 2002 | 11:58 PM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
Transmission: pro-built 700r4: 2400 stall
I was courious the first time I saw that
Btw I'm talking about the Throttle body mounting surface if there is any confusion
Is this better worse than older models ?
Why did they do that ?
Old Feb 8, 2002 | 04:48 AM
93ND500's Avatar
They got rid of it when they deleted the cold start injector. If you look at a throttle body from pre-90 and one 90 - up, you will also see a difference on how they routed the IAC air.
Old Feb 10, 2002 | 12:42 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
85-88 is one style, and 89-92 is the other style. I dunno why it was changed, but the later style funnels the IAC air to the throttle body blades, while the 85-88 uses the triangle on the front of the plenum.
Bubbajones_ya
Jul 6, 2024 08:32 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
edoff13
Sep 11, 2015 03:55 AM
Nick McCardle
Sep 10, 2015 08:36 PM
