Cleaning the TPI Throttle
Old Feb 8, 2002 | 08:34 PM
JAF's Avatar
JAF
What is the best method of cleaning the TPI throttle? Also, anyone out attempt a speark plug replacement?
Old Feb 9, 2002 | 01:24 AM
Guest
Guest
Posts: n/a
Take off the rubber bellows, spray throttle body cleaner (as opposed to carb cleaner) in the throttle body and clean it up, then stick the bellows back on and fire the car up. It might run a little funny until the cleaner is gone.
If youre really adventurous you can do it with the engine running, but be careful and dont let anything get sucked down the intake tract. It will take quite a bit in, like those silly red plastic things you put on the spray nozzle.
Old Feb 9, 2002 | 03:23 AM
Jza's Avatar
Jza
If you're up for it, you should remove it and clean it on a bench with some bore brushes and TB cleaner..
Old Feb 10, 2002 | 07:02 PM
IROCKER's Avatar
If it hasn't been cleaned on a regular basis since it was new then the only real way to clean it is to remove both the plenum and runners from the car and scrub scrub scrub. I recently ported my plenum and figured since I had everything off it would be a good time to clean everything up...It took two bottle of engine degreaser, a bottle of TB cleaner and several wire brushes to get all the gunk out....And I have for the last three years been spraying the TB cleaner in it at least a couple times a summer.
But if you are not up for the task, buy a bottle of TB cleaner. With the car off and the rubber bellow removed, open up the TB butterflys and spray a whole bunch of stuff in there...trying to spray it all over the insides. Use about half the can. Then with an old toothbrush and the butterflys open, scrub the inside of the opening as far in as you can go without losing the toothbrush (of course). Then spray the rest of the can into it. This won't clean out everything, but it's about the best you can do while it's still on the car. Now when you start it up, as mad max mentioned, it's gonna run a little rough at first and will probably throw a code or two. This is too be expected. Just let the car run for a bit to get the crap out of it. Then shut the car down and reset the computer to clear the codes. This can be done but unplugging the ECM fuse or by taking off the negative battery cable for about 60 secs.
Hope that helps.
Old Feb 11, 2002 | 05:19 PM
brian89transam's Avatar
I know this is probably a dumb question but, why do you need to clean it? Does it restrict airflow that much or what?
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
fonzie85
Aug 13, 2015 11:50 AM
Sanjay
Aug 12, 2015 03:41 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
