Stock fuel pump...
Old Feb 10, 2002 | 07:10 PM
Beast5spdGTA's Avatar
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
Stock fuel pump...
How much hp can the stock fuel pump support? I have a 89 305 TPI with 101,000 miles. A little worried about running out of fuel with a 100 shot of N20 or even the 60 shot i run now. My new mph should be around the 100mph mark after a cam swap and few other mods. So I figure ~275hp on motor plus 100 shot = fuel for 375+ hp? Also I bumped my fuel pressure up to ~51 psi. BLMs I saw were around 145-149 if that helps any.
Old Feb 10, 2002 | 08:13 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Here's a chart to help you figure how much fuel pump you need. I do not know the GPH of a stock pump though.
http://www.lt1intake.com/engine_nitrous.htm
Old Feb 10, 2002 | 08:34 PM
Engine: LS7
well, assuming 155 l/hr??(i think that's the smallest fuel pump ratings) gives me like 425hp. I guess I'll try it and check the plugs every now and then.
By any chance did you get a new time with your tranny fixed yet?
Old Feb 11, 2002 | 05:39 AM
Engine: 4.0L
Yes, tranny is fixed. Fuel pump is shot now (inline). When the pump gets hot is shuts down.
Grant2k
Jul 10, 2018 04:01 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
theshackle
Mar 5, 2017 06:37 PM
italiano67
Dec 11, 2016 09:21 AM
NBrehm
Aug 25, 2015 11:49 PM
