do the sr torquer 305 heads take both valve covers
Old Feb 10, 2002 | 09:36 PM
redtail2426's Avatar
Do these heads take both centerbolt valve covers and outside bolt valve covers.Summit sent me the wrong roller rockers that will not work with centerbolt valve covers.And they said that the heads that are also on there way will work with both valve covers.And the roller rockers say they need to have guideplates and hardened pushrods installed and the heads say they dont require guideplates,what is the deal.thanks for anyones help.
Brandon
Old Feb 10, 2002 | 10:58 PM
J's86ROC's Avatar
Car: 1986 IROC-Z
Engine: peanut cam LB9
As far as I know they will take both styles of valve covers.
Old Feb 11, 2002 | 10:41 AM
custman87T/A's Avatar
only if you bought the heads that are before 87. I have the 87 later and only have centerbolt holes.
Old Feb 11, 2002 | 11:15 AM
hey custman did u have install guideplates on the heads or did u need to buy different pushrods?? thanks for the info on the valve covers.
Old Feb 11, 2002 | 12:44 PM
I did a cam swap with new lifters and pushrods and reused the stock 305 heads...after about 100miles one of the rocker studs broke and took a chunk out of the head...that is why I bought the torquers. I used new pushrods again and new rockers and have not had a problem. With the Torquers I do feel a definate SOP increase but I didn't run my car before to get a good baseline. No I didn't use guide plates.
Old Feb 11, 2002 | 01:30 PM
jimjohn's Avatar
THE 305 S/R TORQUERS (87 AND UP) I HAVE WILL ACCEPT EITHER THE CENTER-BOLT COVERS OR THE PERIMETER BOLT COVERS.
THE CENTER BOLT VALVE COVERS WILL NEED SOME MODIFICATION TO FIT PROPERLY.
JIMJOHN
Old Feb 12, 2002 | 07:51 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
the 87+ heads will accept both style valve covers but the bosses for the perimeter covers need to be drilled and taped.that's what i had to do with mine.
Old Feb 12, 2002 | 09:54 AM
jimjohn's Avatar
MINE CAME DRILLED AND TAPPED FOR THE PERIMETER BOLT PATTERN BUT I HAD TO MODIFY THE CENTER-BOLT COVERS TO MAKE THEM FIT.
THE MODIFICATION INVOLVED GRINDING THE INNER RIDGE IN THE COVERS IN THE AREA WHERE THE PERIMETER BOLT BOSSES.
JIM
Old Feb 12, 2002 | 04:09 PM
Ron Mullins's Avatar
Jim, you get me emails?
Old Feb 13, 2002 | 03:04 PM
Checked to see and yes they are drilled for both.
I used the stock centerbolt valve covers and they went on without any tapping or grinding of the covers.
NBrehm
Aug 25, 2015 11:49 PM
db057
Aug 22, 2015 08:17 PM
blackd-out z28
Aug 15, 2015 08:18 PM
Street Lethal
Aug 12, 2015 11:33 AM
mustangman65_79
Aug 8, 2015 01:18 AM
