unplug fuel regulator??
Old Feb 10, 2002 | 10:12 PM
89blackbird's Avatar
I have been told my car will run better just by unplugging the fuel regulator. what up with that?
Old Feb 11, 2002 | 05:35 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Stop listening to your friends.
Unplugging the FPR will send fuel pressure to max the FPR is set at. Also you will have a vaccumm leak.
Old Feb 11, 2002 | 03:27 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Like John said, it will cause a vacuum leak if you don't plug the line you take off and it will be maxing out the fuel pressure in the rails. This will cause the car to run rich and put a serious hurtin on the fuel pump if left that way for long..... Overall it is a bad idea - especially when most stock PROMs are already a bit rich in the first place.
Old Feb 11, 2002 | 05:50 PM
OK thanks. thats why I love this board. One guy that told me that drives a ford.
92camaroJoe
Jul 29, 2023 07:57 PM
9192camaro
16
Feb 3, 2019 12:21 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
