Fuel Pressure Woes
Old Feb 13, 2002 | 05:17 PM
nblanchard's Avatar
Fuel Pressure Woes
Hey guys.. have a problem, well 2. I got my AFPR in now... and an Accel fuel pressure guage.. first of all, the guage jumps all over the place... i do not know why... second, when i rev it up, the pressure seems to drop (i say seems, because the guage jumps around soooo much, its hard to tell).. any ideas?
Old Feb 13, 2002 | 06:53 PM
rhuarc30's Avatar
Well obvioiusly make sure you have everything hooked up right, but also replace teh fuel filter (its cheap and probably needs it anyway). If that doesnt' do it check the fuel pump and sock on the pickup (pain in the butt).
John
Old Feb 13, 2002 | 08:25 PM
nblanchard's Avatar
Yeah.. I think it may be air in the lines. I had problems with the guage seating properly on the Shroader valve, i had to bend the line on the guage straight so it would seat, maybe it's still leaking a tad ( i can't see anything coming out)
Old Feb 14, 2002 | 02:48 AM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Are you checking the fuel pressure with the vacuum line off or on? You need to check it with the line off and properly capped so as not to have a vacuum leak. Either way, it shouldn't be jumping around a bunch like that...... and if you had air in the lines it would be purged by the time the engine starts as the fuel pump would push any air out right away. Something doesn't sound right.........
Old Feb 14, 2002 | 07:07 AM
IROCKER's Avatar
Another thought too Nathan is possible replacing the fuel pump relay...at least before assuming it might be the FP itself. The relay is less than $20 and takes less than 30 seconds to replace...could be a quick fix.
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
