A few questions
Old Feb 16, 2002 | 02:32 PM
LeftTurn1LE's Avatar
A few questions
I'm about to send my old injectors to Rich @ cruzin performance. All I know is that they weren't firing properly which caused the car to run roughly. What other problems could cause this besides them being clogged? I'm already running a set of Accel 24lb injectors so I don't want to spend more money getting the old one cleaned if that is not the problem. You guys have been alot of help in the past and know that I have been having problems with the injectors since I bought the car more than a year ago.
Old Feb 16, 2002 | 03:26 PM
I never checked for electronic damage. Should they read 14-16 ohms same as a 305? These are 22lb injectors for a 350. I read in one of Vader's replies to another post about a switching transistor being damaged from low resistance in the injectors. How can you tell if this has happened?
Old Feb 16, 2002 | 06:24 PM
I just checked their resistance and one is reading 5 ohms. The rest are 15 and 16 ohms. The reason I ask about the transistor is because the car runs about the same with the Accel injectors. I think this is just from being rich though. Any other problems to look for?
fasteddi
Sep 10, 2015 09:32 AM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
