Backfires under load after installing flomatched injectors
Old Feb 16, 2002 | 05:35 PM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Transmission: modified 700R4
Idles nice but when I go to get on it backfires.Couldn't find any vac. leaks any ideas what to check next.
BD3
Old Feb 16, 2002 | 09:49 PM
89BlueTA's Avatar
I am not sure if you took the plug wires off when you swapped injectors or not. But it sounds like you might have a couple wires crossed up.
nick
Old Feb 16, 2002 | 09:57 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
I really wouldn't blame the injectors outright here. You didn't change to 22s on the stock chip did you?
I'd guess tht a vacuum line or some connector isn't on right. Something ordinary like that would seem likely after having the plenum off.
We're still on for the track in a few weeks right. I'll be running 3.42s and who knows what else by then. I don't want to hear no excuses when i'm smokin' you, lol
Old Feb 17, 2002 | 03:11 AM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Ed I'm not blaming the injectors just noting that after swap is when the backfiring started.Would a small vac. leak not effect idle but would under load?
BD3
Old Feb 17, 2002 | 09:59 PM
Ed Maher's Avatar
Car: 04 GTO
Well, with MAF, a vacuum leak can sometimes cause weird ****. So definitely look for that.
I just can't help but think about something like the TPS not set or maybe even the MAF decided to start to go.
theshackle
Sep 17, 2020 08:26 AM
Andrew6.688
Dec 13, 2015 10:59 AM
Red iroc-z 305
Sep 30, 2015 05:22 PM
justin57
Aug 20, 2015 07:05 PM
Firechicken86
Aug 12, 2015 10:07 PM
