Fixed the LT1 intake swap oil leak
Old Feb 18, 2002 | 06:47 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
The orginal LT1 intake swap had an oil leak at the rear distributor. This was caused by the distributor being at an angle. Don't ask me why GM did this, I didn't even notice it till after I did the swap.
Well, I thought about it and modified the spacer to fix the problem. Here's some pics:
Before
After
Old Feb 18, 2002 | 06:52 PM
Pony Killer's Avatar
Car: 1986 Z28
Engine: 355
Transmission: th400
nm the pictures work now
Question.. did it change the timing?
may want to check
Old Feb 18, 2002 | 06:59 PM
Engine: 4.0L
may want to check
Change the timing? All I did was make a angled spacer. The block sets the distributor angle not the intake. Hell the distributor doesn't even touch the hole except for the pad. The intake hole is just a feedthrough.
Old Feb 19, 2002 | 01:48 PM
Car: 1986 Z28
Engine: 355
Transmission: th400
musta been the pictures being different angles or something.... looked like the distributor was a bit cockeyed and sits up a bit higher on the second one.
if the spacer changed how hight the distributor sits, it will sit in a different spot on the gear.. subtle change but if you didn't retime it after you did.. it might have moved the timing a shade.. that's all the point i was roundaboutly trying to make
Old Feb 19, 2002 | 04:17 PM
eddiek's Avatar
John Millican,
You get my email to you last week? Never got a reply, am interested in your LT1 intake conversion..........
Thanks,
eddiek
Old Feb 19, 2002 | 05:06 PM
Engine: 4.0L
Originally posted by eddiek
John Millican,
Thanks,
eddiek
I replyed to all e-mails every day. If you didn't get a reply I didn't receive your e-mail.
Old Feb 19, 2002 | 05:09 PM
Engine: 4.0L
I understand what your saying about the timing gear. Oh and BTW, all GM distributors are at an angle.
The only real point of the pictures was to show the angled distributer shim that's required to set the distributor at the right height.
Old Feb 20, 2002 | 01:33 AM
GhoSSt's Avatar
Looks great John. Now just quit using JB Weld.
Truly, it looks great! :hail:
Old Feb 20, 2002 | 05:44 AM
Engine: 4.0L
I still like the cold weld, I don't like the idea uf using lots of heat on the mate surface. I would much rather have cracked JB Weld then a vacuum leak that can't be fixed.
Old Feb 20, 2002 | 11:34 PM
72LT1VETTE's Avatar
Car: 1972 LT1 Corvette
Engine: 350 HO
Transmission: M22 Heavy Duty 4 Spd
Axle/Gears: 336
John, the pictures look great. The additional light and zoomed in shot not only show a clearer
picture but also show the cut away required in
the EGR valve area for distributor clearance.
I agree with you, JB Weld it" Cast aluminum, like cast iron, requires very special hot welding
procedures and techniques that most certified welders don't even attempt. It must be heated to a specific temperature, weld a little, pean a little, grind a little, heat some more, weld a little, pean a little, and so on. COLD WELD, no
problem.
Old Feb 20, 2002 | 11:49 PM
72LT1VETTE's Avatar
Engine: 350 HO
Axle/Gears: 336
Originally posted by 72LT1VETTE
The additional light and zoomed in shot not only show a clearer picture but also show the cut away required in the EGR valve area for distributor clearance.
This is not visible on your webb site photos
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
Navy8125
Aug 21, 2015 09:32 AM
drathaar907
Aug 6, 2015 04:20 PM
