gas fouling plugs
Old Feb 20, 2002 | 01:19 AM
Stang Stomper85's Avatar
gas fouling plugs
i have a 355 tpi that i just rebuilt and i put 24lb accel injectors in it and it ran fine for a few days now all of a suden it won;t start unless you hold the gas to the floor. when you pull th plugs out they are wet with gas. and it is smoking and missing. i was wanting to know if it could have soething to do with the fuel pressure
thanks
Old Feb 20, 2002 | 06:10 PM
arthur's Avatar
That all depends on what pressure you're running. I have heard that the Accel injectors may 'leak' more than others. If this is now just starting to happen, and the new injectors worked fine for a while, then I would say they are leaking. The engine will start at wide open throttle because it changes the mixture to an acceptable level.
Old Feb 20, 2002 | 11:55 PM
72LT1VETTE's Avatar
Car: 1972 LT1 Corvette
Engine: 350 HO
Transmission: M22 Heavy Duty 4 Spd
Axle/Gears: 336
If your TPI is speed density type, the MAP sensor could be bad or the vacuum hose to it could have a leak. Most common problem.
1992 Trans Am
May 10, 2023 07:19 PM
Infested
May 22, 2018 11:56 PM
db057
Sep 4, 2015 07:57 AM
Thornburg
Aug 30, 2015 08:05 AM
