what kind of tools?
Old Feb 19, 2002 | 10:19 AM
chevyboy07 91's Avatar
what kind of tools?
what assortment of tools do you guys use to get to the distributor tab bolt so we can time the car? I tried crows feet...no luck. Several distributor wrenches...no luck. Ratchet w/ 6" extension and universal joint w/ socket...no luck...that was 3/8" drive though...maybee I need a 1/4" drive ratchet/extension/wobble/socket????? what do you think/know?
Old Feb 20, 2002 | 03:57 PM
ttt
Old Feb 20, 2002 | 04:49 PM
smokin87iroc's Avatar
Car: 87 IROC
Engine: 305 TPI going to LT1
Transmission: 5spd
i use a distributor wrench that fits into a ratchet or breaker bar.
but its not just in a "L" shape its like 2 L's attached it goes down then out a little then down a little more then out the rest of the way.
if i had a camera i would take a pic of it but i can't
it looks like this
. -------0
Old Feb 20, 2002 | 05:04 PM
BlazinOR's Avatar
Re: what kind of tools?
They sell pre-bent distributor wrenches, I have a Snap On one, but you can get them cheaper at most any good auto parts store. Makes it real quick and simple to loosen that bolt.
Old Feb 20, 2002 | 10:11 PM
yeah SMOKIN,
thats the same one I have LOL...its a "PT" performance tools brand right??? S h i t, i can't get even 1/16 of a turn using that thing on there....hmmm, I will have to try some things :/
Old Feb 20, 2002 | 11:17 PM
383GTABoy's Avatar
Car: 88 GTA + Dakota on N20
Engine: 383 4 bolt
Im not sure what you call it but I just use a little socket with a joint in it so that it bends up to 90 degrees. Just use that and a 4" ext and your good. The Socket is a little hard to get on the bolt but I just leave it on there 24/7 and just stick the extension back on to it whenever I want to change my timing.
It works great and never falls off like you think it would.
Old Feb 21, 2002 | 01:12 AM
Car: 87 IROC
Transmission: 5spd
you just have to get the vaccume lines out of the way and you kinda have to tilt the wrench a little so its not flat against the base of the bolt.
Andrew
Gunner242
Dec 25, 2015 04:49 PM
92projectcamaro
Dec 8, 2015 12:25 AM
Reid Fleming
Oct 10, 2015 09:56 PM
hartsmike
Oct 2, 2015 07:11 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
