Can I get rid of this?
Old Feb 18, 2002 | 10:37 PM
Steve10's Avatar
I'm removing everthing I don't need while I'm swapping to the LT1 intake. What is this in the pic below? It's located near the firewall by the coil. One vac port was connected to EGR, the other teed over by the evap. cannister, and it has an electrical connection in back. I'm thinking it's the EGR control. If so, I won't have one and should be able to get rid of it. I've already disabled it in the prom a long time ago anyway.
Old Feb 18, 2002 | 10:54 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
Yup you won't need that. You can get rid of it.
Old Feb 19, 2002 | 05:30 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
Steve
Noticed your set up is close to mine less the cam and runners (and head work). Did you completely modify your chip or just some of the paramaters? I've been looking for a good ZZ4 TPI bin to burn to an extra chip. I also have the 1 5/8 headers, cold air and a 3:23 rear (close to your 3:27).
Old Feb 19, 2002 | 06:05 PM
ImportsRsloths's Avatar
I have almost the same set up to.... anyway i could pay you to burn an extra chip or something???
Old Feb 20, 2002 | 07:43 AM
Steve10's Avatar
Rob, I've modified many parameters in the chip. If you have a MAF car, you should run the 6E calibration and start with the ARAP bin, which is available on the gmecm site bin library. When you say you need a bin to burn to an extra chip, I'm assuming you have the equipment.
Old Feb 20, 2002 | 07:30 PM
Rob P's Avatar
Engine: ZZ4TPI
No, I don't have the equipment currently, but a good friend does. My car is a MAP set up.
IROC ZELLER
Sep 29, 2015 03:00 PM
Zell1luk
Sep 29, 2015 10:36 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
the_hamturdler
Sep 22, 2015 02:59 AM
