Intake Question.....
Old Feb 22, 2002 | 09:33 AM
rocc4u's Avatar
Car: 1992 Z28
Engine: 383 Miniram
What is the best intake to use with the SLP runners and where is a good place to find one......
Thanx
Old Feb 22, 2002 | 06:53 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
I would say that all of the aftermarket intake bases are about equal and will work well with the SLP runners. I would just pick up the cheapest of the bunch and than port match it to the heads and the runners, clean up any flashing from the casting process, and call it good.... If you really want that TPI to pull on the top end you can look at siamesing it as well. There are used bases popping up here and there on the classified boards of this site and othes like www.camaroz28.com for pretty good prices. Otherwise I think the Edelbrock one is the cheapest of the bunch be a hair and can be gotten from Summit or Jegs. TPIS ( www.tpis.com )and Accel/LPE ( www.lingenfelter.com ) also sell upgraded bases.....
Hope that helps,
Matt
Old Feb 22, 2002 | 07:28 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I've been doing some digging, and I've found out that they are NOT all equal. I'm still hoping somebody will mic an Edelbrock intake, but from what I understand, the edelbrock isn't a lot larger than the stock intake. The Accel intake is much, much larger, over 1/4" larger diameter runners than stock. And at $390, it's not much more than the edelbrock.
The TPIS is just a ported edelbrock.
Old Feb 23, 2002 | 02:08 AM
rocc4u's Avatar
Car: 1992 Z28
Engine: 383 Miniram
Muchas Gracias mi amigo's......I think I am gonna look into those a little and see what I can come up with.
Old Feb 23, 2002 | 02:14 AM
rocc4u's Avatar
Car: 1992 Z28
Engine: 383 Miniram
Hey Jim,
Where did you see that base advertised for 390????
I looked at their site and they are asking alot more than that.
Old Feb 23, 2002 | 04:13 PM
Jim85IROC's Avatar
Originally posted by rocc4u
Hey Jim,
www.cruzinperformance.com. There aren't any prices listed on the website, but if you email them, that's the price you'll get.
customblackbird
Oct 1, 2015 04:30 PM
85 Jimmy
Sep 30, 2015 07:56 AM
jerflash
Sep 24, 2015 03:11 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
