O-rings for fuel lines
Old Feb 22, 2002 | 05:50 PM
Markolc's Avatar
Car: '87 IROC
Engine: LT1 350
Transmission: 700-R4
Where can I find new rubber o-rings for the stock hard fule lines? I'm missing one, and the other is kinda dry with slight cracks.
Old Feb 22, 2002 | 06:03 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
At the dealer. I don't know the PNs offhand, but they had no problem looking them up for me when i needed 'em. Less than a buck too.
Old Feb 23, 2002 | 08:17 AM
MikeInAZ's Avatar
Car: 86 T/A
Engine: 5.0 TPI
These are for my 86 T/A. Yours are probably the same:
17111696 Fuel Rail O-Ring Kit - When you replace injectors you will need this kit, however I will tell you this kit contains 8 rings and the fuel rail rebuild calls for 13 including the Schrader Valve and Cold Start Valve. $ 19.85
22514722 O-Ring - Fuel Line in/out of rail. The ones they don't give you. Need this one and one below. This is the larger of the two. .48
22516256 O-Ring - Fuel Line in/out of rail. The ones they don't give you. Need this one and one above. This is the smaller of the two. .47
Red 86 T/A 5.0 TPI (LB9/WS6)
~HyperTech Cap/Coil/Rotor/AFPR
~Derale Adjustable Fan Switch ~ 170° Stat
~Flow Matched Injectors ~ K & N Air Filter
~Ported Plenum ~ Pirelli 245/50/16
~SLP TB Airfoil ~ All Else Stock
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
