What is the distance from the TB mounting to the first intake port??
Old Feb 26, 2002 | 02:21 PM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
I want to know the distance from where air enters the intake on LT1 and miniram manifolds to cylinder 1 intake port. I have heard that minirams have 1,2 cylinder distribution problems because of the shorter distance and thus smaller radius or turning. Is this true?? Is the distance shorter or the same? If the same length how can it be that the LT1 needs clearance from the serp belt tensioner?
Old Feb 26, 2002 | 07:54 PM
Steve91Z28 L98's Avatar
Car: 1991 Camaro Z28
The miniram definitely has less distance from the throttle body to the first intake ports. It has to sit back far enough to clear the water neck. The LT1/4 intake TB mounting surface is practically flush with the front of the block. Sorry, I don't have any exact measurements nor have I seen a miniram in person. I'd like to know which intake has the largest plenum volume. I'm guessing the '92-'93 LT1 intake has the largest volume due to no crossover tube in the top of the intake. I'm also willing to bet the '94-up LT1/4 intake has a larger plenum volume than the miniram. If anyone has any numbers please post them.
Stephen
Old Feb 27, 2002 | 07:46 AM
Car: 1991 Firebird
Engine: 427 LSX
How does your car run with the stock prom?? I knew the mini had to be shorter and I am sure there is a reason that GM designed the LT1/4 intakes with the longer distance, but why???
Frozer!!!
Jan 19, 2024 04:55 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
hayesaw0210
Aug 23, 2015 11:15 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Jake_92RS
Aug 11, 2015 10:39 AM
