Superram fasteners ?
Old Feb 28, 2002 | 06:07 PM
GTABANDIT's Avatar
Can someone give me the correct number and description of the screws needed to put together a superram thanx
Old Feb 28, 2002 | 07:14 PM
a383z's Avatar
what exactly do you need are you talking about the bolts that bolt the box to the runners or ther box to the lid. Please tell me exactly what you need.
Old Mar 1, 2002 | 02:23 AM
93ND500's Avatar
Runners to box....1/4-28 x 3/4" (16)
Box lid................1/4-28 x 1/2" (17)
Old Mar 1, 2002 | 09:42 AM
GTABANDIT's Avatar
Thanx for the hlp guys i also need the runner to base bolts too thanx
Old Mar 1, 2002 | 12:20 PM
shawn87gta's Avatar
I suggest using socket head cap-screws for the runner to base. These are screws that use an allen wrench (not trying to insult you, some people don't know what these are). Get a long ball-end allen wrench, which allows angular engagement at the screw head - allowing it to work kinda like a swivel socket. This should make it easier to install the runners and potentially prevent you from having to remove any of the rockers. Also remember that you have to install the bottom runner bolts in the intake first, then set the slotted hole in the runners down over that. I don't think you can install these bottom bolts with the runners in place.
I have some installation tips that require some light machining (drilling, tapping, installing threaded inserts), but should make the installation much easier. I have not installed my SR yet so I cannot speak from experience, but this is how Rich at Cruzin Performance told me he installs them, and it's what I will do to mine. E-mail me if interested.
Old Mar 2, 2002 | 09:47 PM
Mike89GTA's Avatar
Yea, that's how I did it and it worked fine. Never had to remove the rockers.
ktthecarguy
Jul 5, 2020 11:46 AM
Pac J
May 17, 2020 10:44 AM
Bohemian
Aug 15, 2017 05:11 PM
