running at 225 degrees
My 1988 GTA 350 runs at 225 degrees and has dual fans. The problem is one fan works and is manually activated. What thermostat came stock and how low can I go for best performance and wear.
you run 225 in town or on the highway? also the stock thermo is 195, I'd put in a 180. and a jet fan switch. if you are running that hot down the highway I'm betting some plastic that pushs air inot the radiator is broken off, it was on mine when I first got the car.
Fronzizzle
Mar 18, 2019 08:29 PM
BlackphantomZ28
Aug 31, 2015 10:29 AM
