TPI Problem HELP!!!!!
Old Mar 3, 2002 | 08:22 PM
TrnsmGTA's Avatar
Car: 87 Trans Am
I've been having problems when accelerating, and it feels like alot of turbulence and that the engine is missing big time. Just replaced the O2 sensor, spark plugs, fuel filter, cleaned the injectors and throttle body adn put new gaskets on the runners and intake manifold. It STILL makes this truly bad noise, and shakes the whole car and sometimes almost cuts out at really slow speeds, thought it was hoses so replaced all vacuum hoses i could see. Any suggestions? I really need some help with this!
Old Mar 3, 2002 | 08:51 PM
Der91Z's Avatar
Car: 1993 Toyota Supra
Engine: Inline 6
Transmission: 6 Speed
Axle/Gears: 3.13
Check to see if the plug wires are in the correct order. That would definetely make the car miss. then I would check to see if there are any codes. Then I would check the timing. I would recommend adjust the timing to about 6 degrees to get a good baseline if the timing is off
Old Mar 3, 2002 | 09:16 PM
TrnsmGTA's Avatar
Car: 87 Trans Am
It all seemed to work fine until i replaced the little odd shaped valve with 3 openings (near the left of engine / distributor cap)and replaced all of the hoses to it. Prior i had a screw plugged in them, and the valve was broken.
Grant2k
Jul 10, 2018 04:01 PM
Infested
May 22, 2018 11:56 PM
jbd1969
Aug 17, 2015 07:06 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
