Stupid vacuum leak!
Old Mar 6, 2002 | 11:56 AM
Christos's Avatar
Car: 1986 Iroc Camaro
Transmission: Th700R4 Jr. Raptor
Stupid vacuum leak!
Hey guys. Well, i took off my throttle body a while back to change out the IAC, and in the process, managed to break off a bolt in the IAC housing, which connects it to the throttle body.
I just tossed it back on, and once i did that, i have had a vacuum leak, making my breaks suck, and my engine idle higher then normal. At first i figured it was the new IAC, but i heard a hissing sound when i first installed it again, which quieted after about 60 seconds.
I pulled off the TB once more, and am having a mechanic drill out the broken bolt, then im going to tear it down, and install new gaskets (including a new tb-plenum gasket, even though the other is in sweet shape from the change a few months ago).
Does anyone know how many ft/lbs my tb needs to be torqued to? Also, that broken bolt had a good 3 mm still in the bottom, could it have been causing such a drastic vacuum leak? Just wondering if anyone had any ideas of what to check for while i have it off.
Thanks!
Old Mar 6, 2002 | 07:53 PM
Markolc's Avatar
Car: '87 IROC
Engine: LT1 350
Transmission: 700-R4
18 ft lbs per GM service manual!
Old Mar 7, 2002 | 06:27 PM
Steve87Pont's Avatar
I'll just add the torque for the IAC Coolant housing bolts are 27 in/lbs (3.0 Nm) and the IAC itself would be 13 ft/lbs (18 Nm)
bbsr72
Apr 2, 2016 09:12 AM
86IROC112
Nov 27, 2015 09:54 AM
86maro_252
Oct 10, 2015 06:52 PM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
3rdgenkindagal
Sep 13, 2015 02:02 PM
