Pics of my rebuild and spun rod bearing
Guest
Posts: n/a
I've seen much worse damage than that before. Good thing you caught it before it got much worse, that can be easily machined away. Might consider replacing (or maybe having it resized) at least one of those rods, if not both, they get pretty messed up when a bearing spins in them.
I should post the pics of my old motor that spun a bearing. . it chewed literaly about 1/4 of an inch out of the crank and the two bearing shells fused together, I needed to pry them apart.. . . it got so bad that the piston began to bang into the head and broke a chunk of the land which I have yet to figure out where it went.
ambainb
Apr 25, 2016 09:21 PM
gixxer92
Sep 1, 2015 04:32 PM
someone972
Aug 30, 2015 12:52 AM
