difference in trick flow heads?
Old Mar 6, 2002 | 06:59 PM
u r sofa king we tah did's Avatar
whats the difference between the trick flow 23 degree heads and the trick flow G2 heads?
Old Mar 7, 2002 | 10:07 AM
Desert86Roc's Avatar
The 23* heads are standard type heads....the G2s are twisted wedge with the intake and exhaust valves at different angles.
Old Mar 9, 2002 | 12:34 AM
any differences in the intake runner CC and exaust port CC sizes. or like max lift with the equipped springs?
Old Mar 9, 2002 | 01:09 AM
Blackened's Avatar
You COULD look this up at www.trickflow.com. Make it easy on yourself.
Old Mar 9, 2002 | 01:15 AM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Could you please post the actual Trick Flow link for the G2 heads. I used to be able to look them up at Trick Flow, but I can't find the link anymore.
Thanks,
J
LT1Formula
20
Nov 14, 2015 12:02 AM
gta90
Sep 15, 2015 04:00 PM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
tmellott89
Aug 16, 2015 02:58 PM
