Can you use '87 SLP runners on a '91???
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
I was wondering what the difference is btn the SLP runners they have for pre'88 and the ones for '89-'92. Can I use the older ones on my '91 SD TPI setup???
Car: '91 GTA
Engine: 402ci LS2
Re:
Thanks! Thats what I was thinking. I guess there is a bolt hole there also to bolt the blocking plate to?? later
Yes, there is a bolt hole there. I don't know how well a plate would work. You could get an old injector out of the junkyard and cut the fuel line or something. I'm sure someone else has done this. Later
no green
Jan 9, 2016 09:22 PM
Royal_Z
Sep 30, 2015 08:45 PM
Dragonsys
Sep 25, 2015 03:51 PM
