this comp-cam good for 383 tpi?
hey guys, I am still very indecisive regarding my cam selection for my 383 TPI(not built yet). My camaro has a '88 corvette L-98 with the factory aluminum heads, 700r4 tranny(B&M), 9-bolt(3:27)rear, probably going with a 2500 stall converter, headers(no cats), 3"flowmaster exhaust. The stroker kit I purchased comes with a eagle cast crank, eagle rods, kieth brown pistons, clevite rings, mogul bearings. I will be retaining the factory intake tpi set-up for now. The cam in question is the compcam cs-290hr-12(hyd roller) duration @.050lift 230/244, lift.510/.540, 112*lobe separation. Is this good for a street/strip application+daily summer driving? Please let me know of any other cams that might be better. Thanks!!
That durations a little high, the rest looks good
You'll need to do some serious prom tuning, even on a 383.
If you're going stock TPI, you certainly can't USE high duration, cuz bottom line you WONT rev, not only is it increadibly restrictive, but your stroker will create more friction and rotational resistance at any RPM's than the 350.
I recommend duration at .050 to be somewhere in teh 224/230 range on your 383 if you plan on upping your intake soon.
Car: 89 IrocZ
Engine: L98-ish
I think the #'s look good for a 383...may want to check with Crane on idle vac, etc...but the extra cubes should support it.
I'd hold off on the converter until after the engine is spec'ed out.
Seriously think about doing something with the intake though..big cubes and a cam that want's high RPMs, isn't going to work well with the stock setup (IMO).
Car: 89 IrocZ
Engine: L98-ish
Also, I might mention you may need to rethink the engine combo...you'll most likely have to put some money into the current heads to handle the new cam specs...but will they be up to the 383's requirements without getting in and hogging them out? No use building a stroker, in my opinion, unless you're going after some decent power..the '70's and 80's were filled with big-cubed engines with no HP
Originally posted by KDoggsPimpJetta
well throw a different cam in there and im sure he could see the 20/20 pick up .....
no need for carbs
no need for carbs
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
In my opinion, a good choice in cam would be the LPE #74219
219/219 .525/.525 112lsa. This is one of the most versatile cams out there for a TPI. The specs may seem tame but a friend of mine went 11.55@121 with that cam in his Vette with a 383 and MR. Go into my web sight and look at "BadBowties".
www.geocities.com/dzperf
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Originally posted by Blackened
Desktop Dyno says it'll make 378HP and 397 TQ at 5000 RPM. Looks pretty good! A single plan manifold and 750CFM carb would make 400 HP at 5000 RPM and 420 pounds of TQ.
p.s. this is why I went with a carb.
As for the original combo, I agree the cam you've listed is too big for what you want... The GMPP LT4 HOT cam would be a good choice for the L98 heads and stock TPI. Also the LPE219 cam. If you want a little more, GMPP also makes a 224/230 cam. I cant remember its part number but its listed in their catalog. If you want to use a 230/244 cam, I would very highly recommend some other intake such as a MiniRam, LT1 intake, or the new Holley Stealth Ram.
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
I agree wih HiTech5, LPE 219. I have it and like it a lot. I've seen many mid 11 sec.-low 12 sec. N/A Vettes with this cam. Here are some more combos to look at:
http://temp.corvetteforum.net/c4/bea...enSetups.shtml
Sanjay
Aug 12, 2015 03:41 PM
