Help with 86 tpi T/A (LB9)
Old Mar 9, 2002 | 02:30 AM
86305's Avatar
Just wondering if anyone could help me out by giving me some ideas for some mods on an 86 tpi 305. I have an extra 305 that i want to build and drop in. Need info in good heads to use, pistons, roller rockers, roller cam, roller lifters. Don't know anything about picking a cam. I need something for a good street and strip application.
Old Mar 9, 2002 | 10:36 AM
86305's Avatar
come on guys help me out a little.
Old Mar 9, 2002 | 11:52 AM
avro206's Avatar
Car: 89 Formula
Transmission: TH 700R4
Good for you! Building up a 305.
How fast are you shooting for?
I'd reccomend LT4 cam, Edlebrock E-Tec 170 heads and a SDPC
Vortec TPI intake.
Old Mar 13, 2002 | 07:59 AM
86305's Avatar
I want to see if i can get atleast 12's even if i have to juice it. ANy suggestion on the lift and duration i should choose for the cam.
Old Mar 13, 2002 | 10:13 AM
Vader's Avatar
86,
Go west, young man. At least to Tennessee. That's where you can contact Competittion Cams, and request a copy of their Catalog 106. It will have a lot of valuable information about cam selection, design, installation and degreeing, theory, etc., as well as a full range of standard selections for you engine.
You can also get them at 1-800-999-0853 or www.compcams.com
It's at least a good starting point.
Old Mar 13, 2002 | 04:59 PM
86305's Avatar
OK Should i go with a cam that i will have to change my torque converter or should i go with the 270h magnum and stay with my stock converter.
Sorry for bothering you guys about all this but i'm an amateur.
Old Mar 13, 2002 | 07:47 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
go to www.fl-thirdgen.org and look on the front page and find the link to an article on a 325hp 305 buildup.
Old Mar 13, 2002 | 08:01 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
I don't know much about 305's, but you might try going to the Comp Cams webpage. They have a form you can fill out with engine specs. They send you cam recommendations.
J
gta90
Sep 15, 2015 04:00 PM
mrestrictrplate
Aug 27, 2015 09:37 AM
Akinnepa
Convertibles
Aug 26, 2015 10:54 AM
happyhapka
Aug 15, 2015 04:42 PM
Sanjay
Aug 12, 2015 03:41 PM
