Mass Air flow Voltage readings
Old Mar 9, 2002 | 02:56 PM
Ratchet's Avatar
I have a 1986 V6 and the code for Mass air flow is on. Also stalls at stops.
I need to know how to check the MAF to see if it needs to be replaced.
This is a V6 and there are three wires coming out of the MAF sensor. What voltage on what wire should I be looking for to determine if MAF sensor is good or bad.
Old Mar 9, 2002 | 04:09 PM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
I do not have a V6 but when i my car was stalling at red lights and was getting code 34 ( MAF low) i replaced both relays and the problem went away.
I have directions how to check the V8's MAF sensor but not for V6.
Check the connections from ECM to MAF. Are they all OK?
Good luck.
Old Mar 9, 2002 | 04:27 PM
Ratchet's Avatar
Thanks I checked the plug about 4 times and it seems to be ok
There is a black wire that goes to ground and I checked it with key of it has 0 resistance.
There is a brown wire in the center and with the key turned off has 0 volts turn key on engine not running 4.8 volts turn key on engine running at idle and voltage drops to 2.7volts. (If you rev the engine there is no increase in voltage at all.
The last wire going to the plug has 12.8 volts with key on engine not running and 13.5-14 with engine running (orange)
Old Mar 10, 2002 | 11:41 PM
Ratchet's Avatar
Problem solved.
Sprayed inside of throtle bod y with throtle body cleaner and car does not stall anymore.
eightsixseven
Dec 16, 2024 01:50 PM
chazman
Aug 28, 2018 03:25 PM
Keith5
Aug 27, 2015 04:37 PM
chazman
Aug 22, 2015 02:01 PM
