differences in two LPE cams
Old Mar 10, 2002 | 06:33 PM
JAJ's Avatar
JAJ
Engine
Induction
Dur @.050"
Lift w/ 1.5
Lift w/ 1.6
C/L
Cam
SBC 305-383
LT1, L98
211/219
.499"/.525"
.533"/.560"
112
74211
SBC 305-420
LT1, L98
213/219
.462"/.471"
.493"/.502"
112
74216
Obviously, the lift is different and that is why I'm looking at going w/ # 74216 on my stock head L98. Springs/clearance will be dealt w/ but I just want a simple LTR setup that will run decent. Intake and exhaust are already taken care of . . . Is there really anything sgnificant between these cams that I'm missing as I know #74211 if often recommended in LTR cars, I just don't hear much about #74216.
Old Mar 10, 2002 | 06:44 PM
tpivette89's Avatar
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
this is a subject i am starting to learn about (cam profiles), and from what ive read, i seems like the only main difference is the slightly more intake duration on the 216 cam over the 211. also, the lift on the 211 is greater, as you mentioned, and would not be recommended for stock type spring applications. i would go with the 216 in your case (when i decide its cam swap time in my vette, this is the bumpstick i am going with).
Old Mar 10, 2002 | 07:54 PM
Mark 89Formula's Avatar
You guys have got it right. If you keep the stock GM heads you shouldn't have to machine the valve guides when running the 216. The 211 has a little more performance potential due to the higher lift, but not enough to get excited about.
Jake_92RS
Jan 28, 2020 10:37 PM
bamaboy0323
Sep 3, 2015 06:07 AM
masonta
Aug 31, 2015 10:14 PM
neekolzun
Aug 24, 2015 04:59 PM
Thirim
Aug 13, 2015 03:09 PM
