How much difference between L98 Iron & Aluminum heads?
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
I'm thinking about just doing alot of port work to my iron L98 heads I have. How much better are the vette alum ones? I'm going to be running the LT4 hot cam, siamesed base, SLP runners, headers, exhaust, custom PROM, T56, 3.42s, 3" cutout, Holley 255lph, Holley AFPR, and all the little stuff on my website. I'm wanting at least high 12's out of it. I think thats possible. Are these heads worth it or should I get some vette ones? If so, how much would that swap cost me?? THANKS
Car: 88 Trans Am
Engine: lt1 intaked 355 makin 277 on 25 psi of fuel pressure and stock timing :)
Transmission: A4 stock... that moved a mobile dyno a foot shifting into 2nd :)
1st thing is weight....the cast iron heads are heavy as H#!! and the vettes are very light... and 2nd is the combustion chamber sizes.... the cast irons have 64cc chambers and the vette heads have 58cc heads and d shape exhaust ports
The aluminum heads also have quite a bit more low lift flow. Here's the flow #'s
Corvette Aluminum # 113
Lift/Intake/Exhaust
.100 62 49
.200 116 98
.300 161 130
.400 185 152
.500 195 159
350 Cast Iron # 083
Lift/Intake/Exhaust
.100 44 41
.200 101 82
.300 155 125
.400 182 137
.500 196 140
Lift/Intake/Exhaust
.100 62 49
.200 116 98
.300 161 130
.400 185 152
.500 195 159
350 Cast Iron # 083
Lift/Intake/Exhaust
.100 44 41
.200 101 82
.300 155 125
.400 182 137
.500 196 140
Car: '91 GTA
Engine: 402ci LS2
re
Thanks guys. I knew they were 58cc, lighter and d-ports, but I wasn't sure exactly how much better they flowed. To me that doesn't look like that much difference. I plan on porting the hell out of these iron heads... I think they'll be fine until I can afford AFR's and a LT1 intake. Thanks
Car: '91 GTA
Engine: 402ci LS2
re
No one else has any thoughts??? I'm just wondering how they will do with that LT4hot cam. Thanks
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I dunno... how does 12.80 sound with Corvette L98 heads and an LT4 HOT cam?
Car: '91 GTA
Engine: 402ci LS2
re
Thanks Kevin. Thats a pretty good time for ya I'd say. I was wondering how much I'll lose (if anything) by running fully ported iron heads? Thanks
Nope, no problem with the valves hitting the pistons. I'm using 1.52 roller rockers so only .498" lift. I think I used a .040" thick head gasket.
Car: '91 GTA
Engine: 402ci LS2
re
Yeah, if I use 1:6's on the iron heads with the hot cam... will they clear or will I have to mill the guides down or what? Thanks for all this help Kevin. I'm getting closer!
Car: '87 Camaro LT
Engine: 355 L98
you'll have to mill them even if you use 1.5 rockers. i have the hot cam and had my guides milled .050 but i think it should have been more like .080.
Car: '91 GTA
Engine: 402ci LS2
re
Thats cool. I was wondering what I would have to mill down. So how much do you think I'd have to go with 1:6's on iron heads? I think I'm gonna get the LT4 spring kit from SDPC. Where's Kevin at on this issue. lol Thanks again
in david vizard's "How to build and modify small block chevy cylinder heads", it states there is absolutely no power gain difference in a set of fully ported corvette alum L98 heads and a fully ported iron head. he says to only pick them up if you can get them for a good price. it even goes on to state that if you plan on making more than 400hp, the corvette head is too questionable at this leve because it is too fragile.
Car: '91 GTA
Engine: 402ci LS2
thanks man. I still need to know how much to mill my guides down for clearance. Thanks!!
