Knock sensors.
Old Mar 12, 2002 | 03:33 AM
PerthZ28's Avatar
Knock sensors.
Is the standard knock sensor for a standard TPI 350 the one to use or is there another one that gives better results? I vaguely remember something about using the LT4 one or was that for a ZZ4 engine or something??
Old Mar 12, 2002 | 01:14 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
The LT4 knock module is for the LT1/4 PCM, and is only the filter, not the sensor. It's not applicable to a TPI motor. Some people have had minor success in desensitizing the knock sensor using a small amount of teflon tape to absorb vibrations, and others have used some resistors spliced in with the KS. Only do this if you're sure that the knock you're seeing is false, though!
Old Mar 12, 2002 | 06:42 PM
PerthZ28's Avatar
Knock sensors.
Does anyone have the right part number for the knock sensor for the '88 350?
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
efiguy
Sep 27, 2015 01:30 PM
spartanreaper
Sep 25, 2015 07:22 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
