after running for an hour or so the car starts to hesitate ?
Old Mar 13, 2002 | 07:33 AM
NEOMASTERZ28's Avatar
Car: 85 z28
the car run fine untill i drive it constanty for an hour then when you are driving slow and rpms around 1500 and then it starts to choke and hesitate then i give it more gas and it comes out of it then while its doing this the fuel lines and fuel rail and injectors are pulseing and vibrating loud
i just put a new fuel pump 1 month ago, fuel fiter about 5 months ago and this was a problem before i even put the new pump people tell me its the fuel pressure regulator or o2 sensor can any 1 help me on this ?
85 z28
k&n
tb bypass
Old Mar 13, 2002 | 10:04 PM
Car: 85 z28
ANY 1 CAN HELP WITH THIS POST
Old Mar 15, 2002 | 01:31 PM
MrJ's Avatar
MrJ
it may sound odd but it could be a failing ignition module.. ive heard of them causing things like this before
Old Mar 15, 2002 | 01:50 PM
Bort62's Avatar
What's that supposed to mean ?
Old Mar 19, 2002 | 07:56 AM
Car: 85 z28
ITS hard to explain but they are vibrating the fule lines and injectors dont know wtf it is but its getting on my nerves
Old Mar 19, 2002 | 11:41 PM
86TPI327's Avatar
I don't know about the vibrating lines and injectors,but my 87 Iroc w/ 350 TPI does the same "hesitation" after I get stuck in a traffic jam,or have to drive slow for extended periods of time.We've narrowed it down to a "vapor lock" of sorts,as the underhood heat boils the fuel in the rails.....I've had it stall out before if I didn't feather the gas just right.Once I start driving again(normally),it goes away.This only happens to me after the car is at normal operating temps.,and then I get stuck in extended periods of slow driving or sitting at an idle for a period of time(like traffic jams and such) it pisses me off ,especially if it does die and I have to get it restarted and get it to drive.I've been thru three ignition modules,and tried a couple different coils,so it isn't my ignition...it's definately a heat build up problem in traffic.I live in Tampa,Florida....so driving in inferno weather in the summer doesn't help .........my engine temp itself stays very cool,it's just in the fuel "boiling".
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
