TPI swap what do I need (no emissions, 60's era car)
Old Mar 13, 2002 | 01:20 PM
SlowCamaro88SC's Avatar
Ok guys, it's about high that I get my 1966 Impala going. I'm a kid of the 80's, so I really don't know carb, but I know TPI pretty darn well. I'd like to get a new 4-bolt 350, and use a TPI unit to replace the tired 283, and 2-bbl rochester carb. Emmisions are not a worry, so if anyone can direct me to what I need to do here, I'd be grateful. I can't afford a new motor, or a hopped up motor, but my goal is to find a 4-bolt 350, toss on headers, and obviously dual 2 1/2 pipes to 40 series flowmasters. 3:73's will be in the cards. If I can find a 12 bolt from a 396/427 donor, It'll go in. For the time being I'll have to live with the 3 on the tree, but eventually, I'd like to swap in a T-56, and then 4:10 gears.
Obviously these are big plans
but by fall I want
*a 355 w/ TPI
*upgrade/replace original suspension pieces (locate bigger sway bar if possible)
*put my IROC wheels on it.
*scuff up the original paint, and primer it (black)
*Do something about the bench seat in front, get new seatbelts. recarpet the floor black.
*Get tachometer, and replace odiot lights with gauges. Find a place to mount them, since the car has dealer AC.
just a kid with a dream.
Old Mar 15, 2002 | 12:50 PM
claycityman's Avatar
im putting a 91 305tpi in my 68 camaro and it has been prety easy so far here is some web pages to get you on your way http://www.700r4.com http://www.painlessperformance.com/ and here is my web page it might help and you can email me anytime http://www.geocities.com/claycitydude/68 and here is a far better forum that will respond to you post sometime it seem the only time people respond on this one is to make fun of you http://www.camaros.net/cgi-bin/forum...assCookie=true
Old Mar 16, 2002 | 12:35 AM
80CamaroCab's Avatar
Re: TPI swap what do I need (no emissions, 60's era car)
but by fall I want
*a 355 w/ TPI
This is a site that help me much, it learn me erverything about tpi.
www.chevythunder.com/index.html take a look.
But if you are going to swap a 350 tpi into your car think abaut the transmission to a swap in a 700r4 trannsmission and it is wort it
Terje
Attached Thumbnails TPI swap what do I need (no emissions, 60's era car)-camaro-cab.jpg
Old Mar 16, 2002 | 09:26 PM
no automatic for me. The trans is typical 60's. (long gears, only a 3 speed. But when I can gather the coin, I'll try for a T-56 swap. A T-5, if it can handle it. I need overdrive.
I figure, it's my car, I'll do what I want with the trans, and when it comes down to it, i'l rather keep the manual than get rid of it. besides everything is already there. Easier than converting a 2 speed powerglide to a 5 or 6 speed manual.
Old Mar 16, 2002 | 09:33 PM
topdown's Avatar
4-bolt mains have a good WOW factor but unless you're building 600hp a 2 bolt might save you some cash...same with the 12 bolt (though a great rear end). If you're not running slicks you probably won't break a good 10 bolt.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
NBrehm
Aug 25, 2015 11:49 PM
jharrison5
Aug 19, 2015 05:53 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
