Custom cold air...is 3" enough?
A guy in the maintenance shop at work can build me a cold air intake out of the stainless materials they have laying around. I measured the pipe at 3" ID, and he will butt weld 3" 90 elbows on. Do you think 3" allows enough airflow? I could go up to 4", but it would neck down to the 3" MAF anyway.
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
yeah, but since the 58mm is too big I think you will be fine with a 3 in. Also remember that inside the TB when it is open are the throttle plates which reduce area and cause some sort of turbulence.
Hotrodboba400
Dec 10, 2019 07:07 PM
