What size K&N filter for COLD AIR
I plan on building a K&N filter for my 1987 TPI set up. I plan out building a system to come out of my throttle body, bending to my MAF and then down . What size Kn should i put on the end..prolly 3-4" diameter...what is the part number
thanks
aj
thanks
aj
Maybe Kandied will share--his intake setup is NICE! Thanks for the reply to that PM, Kandied. I would like to know exactly how you routed the pipe and what, how much metal you cut and where you took it out from to make room for the pipe.
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
When I made my CAI I used a 3 in cone. I had a 3in 90 degree rubber plumbing hose connected to 3in exhaust tubing, connect to the stock 45 degree MAF with the cone at the end where the old airbox was. It was easy to do.
Brinkkl2000
Aug 4, 2018 08:29 AM
toronto formula
Nov 10, 2015 06:17 AM
kyle5647
Aug 15, 2015 11:56 PM
db057
Aug 11, 2015 10:11 PM
