Backfiring and code 42
Old Mar 15, 2002 | 06:18 PM
Mike89GTA's Avatar
I took my car in for emissions and it passed however as I was driving home it started backfiring. I checked the cap/rotor/wires/plugs (all are new anyway) and they all are fine. Strangely though, when I go to check teh timing and I unplug the brown EST wire, it doesn't make any difference in idle. The EST and distributor both have 125k on them, so does the coil. Any ideas?
Thanks,
Mike89GTA
Old Mar 15, 2002 | 10:59 PM
u r sofa king we tah did's Avatar
i wouldnt believe the book on this one. i chased that same problem around in my corvette forever. it wound up being a bad computer, throwing code 42 about 90% of the time when you would start it. occasionally it would run without the code 42, but once it threw the code, it started running like crap, backfiring, and whatnot. i finally tested the computer from my iroc in the corvette, bam, problem solved.
btw, code 42 is supposed to be a fault in the ignition module, but i replaced that, traced the wiring completely back to the ecm, and still came up empty handed until i tried the computer as a last resort.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
